here is a screenshot of the settings.
In this specific case, that arc is made of 16 facets (if
counted them correctly) hence I estimate the deviation
(chord error) to be about 1-2 hundredths mm.
Will send the C init file
Thank you
EC
---In
DynoMotion@yahoogroups.com,
<tk@...> wrote :
Hi EC,
Please post your Tool Setup | Trajectory Planner
Settings.
Also your Initialization C File.
How much would you estimate the "facet" path deviates
from the
theoretical arc path?
On 2017-04-30 05:04, ericnc@...
[DynoMotion] wrote:
> Hello,
> in some circumstances I get faceted arcs even
if "arcs to segments" is
> disabled. (Maybe it's not faceted, it's
difficult to tell whether they
> are facets or other artifacts that make it look
like it was faceted.)
> example of a circumstance triggering the
problem:
> using KmotionCNC 4.34h
> units mm
> problem arc is:
> starting point X13.3343 Y47.6702
> G3 X0.0 Y49.5 I-13.3343 J-47.6702
> G3 X-13.3343 Y47.6702 I0.0 J-49.5
> using these feeds I get the artifacts:
> F40.8
> F89.1
> F123.75
> F129.6
> using these other feeds I do NOT get the
artifacts:
> F137.7
> F145.8
> F153.9
> F148.5
> Long description of the problem:
> It happened first a couple months ago, all the
arcs of the workpiece
> were correctly machined as arcs except the arc
with the larger radius,
> which was "faceted". I failed to report it on
this list but now it
> just happened again with a different workpiece.
> Again, "arcs to segments" is disabled but the
arc having the larger
> radius in the workpiece looks like is faceted
(it's the arc reported
> above).
> I suspect it is a numerical problem affecting
certain combinations of
> feed and radius. This time I did repeated
testing (I had several
> workpieces to do) and could see that the
problem happened with certain
> feeds but didn't happen with slightly faster
feeds.
> I also considered it could be some instability
problem of my badly
> tuned servos, but then I'd expect the artifacts
to happen more
> randomly. These happen very regularly instead,
and happen exactly in
> the same places at different "Z" heights.
> I was doing "2D 1/2" parts, contouring on the
XY plane and repeating
> same contour at different Z levels.
> At you end you get perfect "vertical stripes"
i.e the "faceting"
> happened exactly in same positions at each Z
height, looking much more
> like something generated by the software in
exact same positions at
> each Z level, than some random vibration of the
servos (which I'd
> expect to happen differently at each Z height).
> Please note that it may be weeks/months before
I have to machine again
> these same parts so even if a fix is made, I
won't be able to give
> feedback immediately....
> Thank you
> EC
